Keeps coming up as Error 502  [Solved]
Post by Quirrell » 05 Nov 2018, 16:03
I bought the application now i'm trying to register on the application and it keeps saying 'An error occured while checking registration: 502 Bad gateway' 'Be sure that your internet connection works as expected and retry later'
I've turned my WI-FI off and on but still no use.
Quirrell
Re: Keeps coming up as Error 502  [Solved]
Post by HanFox » 06 Nov 2018, 11:25
Are you using a proxy? If so make sure your proxy settings are setup correctly as Cubik Studio tries to use your system proxy settings to communicate with the webserver.
