Fix the damn .java exporter already
Post by huiAPPOAJ » 27 Aug 2018, 08:54
I've bought Cubik for this one feature - to be able to make voxel models, then convert them to primitives and export in .java to use them in my 1.7.10 minecraft mods. However it didn't work right (you know what the problem is - rotation and position of the models are completely off) and I continued making models in Techne. I've been lurking on this forum for nearly a year to see if you fix this problem. And you still haven't even in 2.9.
So could you please fix it for real? I'm sure I'm not the only one who wants this to be fixed.
huiAPPOAJ
Re: Fix the damn .java exporter already
Post by Sphax » 03 Sep 2018, 09:17
This is a known issue and it's on the todolist. I'm very sorry for the delay on that fix, 2.9 should have improved that but, looks like that's not always the case depending on the model complexity.
Post by goodie » 23 Oct 2018, 12:17
I also need exporting to java... When it will be fixed ?
goodie
Return to “Suggestions”
