obj to json problem [Solved]
obj to json problem
hi, i imported an obj model with its texture to cubik studio, then i voxelized it, and the textures still be there and all fine but no elements appear, either way, i tried to export it to json but of couse it didnt work, anyone knows what is the problem?
- theismarius
- theismarius
- theismarius
Re: obj to json problem
Yes that happens indeed, try to load the new textures and then apply them to the elements.
When your texture is imported, then click a element and press ctrl+a, that way you select all elements...
or hold ctr+click element for individual element selections...
When those are selected apply your texture and adjust UV if needed
- theismarius
you can try the Original one, but you'll need to apply the correct UV area to the elements...
The pallet should be applied already if i'm not mistaking.
- theismarius
you should be able to, i'm not too sure how to do this the easiest way, Also did it generate a voxel texture pallet?
if so, try to convert it to elements first.
