missing texture with shields  [Solved]
Post by Waggles » 26 Jun 2018, 14:46
So I created a shield model for minecraft and when I get into the game it has the "missing texture" texture, I did load the texture onto the model in cubik itself and saved it in a folder named "custom" in the textures folder. Do I have to put the texture somewhere else with shields?
Waggles
Re: missing texture with shields
Post by HanFox » 26 Jun 2018, 15:13
Replacing models all work the same. You just need to make sure the defined paths are correct in the JSON.
A small resourcepack showing your shield changes would help to figure out the issue.
Post by Waggles » 26 Jun 2018, 15:18
HanFox wrote: 26 Jun 2018, 15:13 Replacing models all work the same. You just need to make sure the defined paths are correct in the JSON.
thank you,a I fixed it
Waggles
