If you're behind a proxy you need to set your computer up to negotitate https connections via your proxy correctly (as Cubik Studio uses https to verify your registration).
You'll likely have to search the web for technical details.
Cubik Serial not working ._. [Solved]
Re: Cubik Serial not working ._. [Solved]
