I'm having this same exact problem. I purchased Cubik Studio, I'm not upgrading from Cubik Pro. Since I never got the email with my serial key, I used the recover form, then logged in on my account and obtained my key through the cubik.studio/get page. I'm entering the email address I used to buy cubik studio and registered my account to correctly, and pasting the serial key in from the website (making sure that I'm showing the full key and that I'm pasting in the BDC key, not the BCS key), but I'm getting the same error message as karahanio.
"An error occured while checking registration:
The license information entered contains one or more error..."
It would be really helpful if the updater told us what the errors were, rather than just saying that there were errors.
My Serial Key Does Not Work [Solved]
Re: My Serial Key Does Not Work
Sorry if I'm stealing into this topic, however before opening a topic with the same exact error, its best I chime in saying this Exact Same Error is happening to me. Attempted to try it 3 different times, and each time it shows the same error.
Specs: I have an older HP 2000 Series Laptop, 8 GB RAM, 64-bit Windows 8.1, AMD E2-1800 APU with Radeon HD Graphics, AMD Radeon HD 7340 Graphics
ERROR
An error occurred while checking registration:
UPDATE: Found a fix on my side, after another hour of testing different methods it seems removing all capital letters from my email address and using LOWER CASE ONLY it works just fine. It seems the Cubik Studio Updater reads from the database in only lowercase format. If this works for you, make sure to let staff know this fixed it for you, and see if they can add a way for it to automagically convert emails to lower case before sending a check to the server.
My email address is already all lowercase, so that's no good for me. I also tried restarting the updater and restarting my computer, neither of which were successful.
Nah, I was using lowercase format in my e-mail as @bitKoder. I tried serial key in lowercase format too but didn't help. You luckyDEMMERS wrote: 05 Nov 2016, 03:29 UPDATE: Found a fix on my side, after another hour of testing different methods it seems removing all capital letters from my email address and using LOWER CASE ONLY it works just fine. It seems the Cubik Studio Updater reads from the database in only lowercase format. If this works for you, make sure to let staff know this fixed it for you, and see if they can add a way for it to automagically convert emails to lower case before sending a check to the server.
I guess there is something about our computer or the software, I don't think the problem is about serial keys because when I enter random serial key than program prints "An unknown error occured while checking your license information" but when I enter it correct it prints "The license information entered contains one or more error..." so that means our email + serial is absolutely correct as Sphax said.
I am not really sad about this because I was waiting for real time to buy Cubik Pro and Cubik Studio so waiting for 3-4 days doesn't a big deal for me
Please send me in PM the email and the serial you are entering in Cubik Updater and the OS you are using
I'm having the same problem.
So there's no solution?
You can probably use Cubik Studio in another computer well but there is no solution for now.
What computer are you using?karahanio wrote: 04 Nov 2016, 15:59 Nope, Cubik Updater prints error "The license information entered contains one or more error..." and doesn't do anything for me.
I don't think that is something related the hardware. I am using Windows 10 Pro x64 as operation system.
