It is adding MANY new (small and big) features and fix several annoying bugs...
The new features you should not miss are the support for inverted elements, the easier UV editor, the customizable keys for several commands, the Schematic exporter, the possiblity to drag&drop a file directly in Cubik window to open it (on Windows), the support of DDS and TGA files for textures and a better Cubik file browser! Be sure to check all of that!
We sincerely hope this new version will please you and be sure that we'll continue to improve the software.
Added "Invert Normals" option to element settings
Added new "Inflate" function for elements
New element now uses first available texture instead of using "texture" which can be missing
Disable views rendering while converting voxels to elements and while optimizing elements (to boost process speed)
New "Move to top" and "Move to bottom" options in elements list and meshes list
Keyboard arrows can now move UV on UV editor
Voxel selection is now refreshed after the use of a tool, improving all voxel tools
Faster and more accurate line tool on textures and on voxels
Added line thickness for pixels and voxels line tool
Increased maximum texture size to graphic card max texture size / 2 with minimum 512
Improved color selection and color palette sync
New function "Remove alpha" for Mesh texture menu
Primitives are now using same material and shaders as elements (so meshes can be exact same colors as elements)
Skin preview is now using same material and shaders as elements
Picture Importer now supports DDS format
Picture Importer now supports TGA format (truecolor only, both RLE and RAW)
Improved PNG Import dialog
Implemented a preview panel to Cubik Browser
Cameras are now saved in .cubik format + Fixed bug with grid settings not loaded from .cubik format
Implemented shortcuts for paths in Cubik filebrowser (%minecraft%, %staxel%, %stonehearth%, %steam%, %backup%, %app%, %data%, %desktop%, %appdata% and more...)
Added "Include elements name" option to Minecraft format
Added Schematic Exporter
File > Save menu now acts exactly like Save as if never saved before
Minecraft JSON format supports inverted elements
Fixed .java format
Exported PNG now fully support transparency (and are faster to render)
Implemented drag&drop of file in Cubik Studio window (Windows only)
Added option "Large" to grid settings, so the grid is nearly infinite
Added option to toggle background size
New menu item "Browse last save/export Folder" in "Tools" menu
Left Shift and left Ctrl are now behaving exactly like right Shift and right Ctrl!!!
Rotate mode is now set by default to key 1 and Scale mode is now set to key 2
New options in advanced preferences to customize keys for Scale, Rotate, Clone, Pan, Focus
Added new Minecraft model type "Map" (used by schematic importer and exporter)
Numeric input fields are now scrollable to increment/decrement value
Force save logs in case of error/assert/exception
Open folder where logs file is only one time in case of error/assert/exception
Added logs for OS, CPU, RAM, VRAM, Shaders Model, Max texture size
Improved InputField UI component
Expandable Model Properties dialog
Simplified options text of Voxel setup dialog
Simplified text for grid settings dialog
Removed bdcraft email from Cubik error messages (forum url is visible instead)
Modified some error messages to be more understandable (hopefully)
Better formatted debug logs
- Fixed bug with texture edited externally
- Fixed bug with decimals when exporting Minecraft .json format
- Fixed crash of Cubik FileBrowser on some systems (because of a bug in DateTime class port to Mono), that crash prevented the file browser window to be closed
- Fixed bug with Cubik filebrowser when displaying root/logical drives
- Fixed Bug: Maximizing a view then going to Preview breaks the views
- Fixed bug with "Avoid bleeding textures" option in model properties
- Fixed bug with window moved outside of visible screen (because of bad value for windowX or windowY)
- Fixed bug with broke F2 shortcut (Rename selection) introduced in 2.8
- Fixed bug with delete function in Elements or Meshes lists
- Fixed bug while extruding PNG with optimized elements
- Fixed bug with "Enable Symmetry" menu which didn't work
- Fixed bug of "Customize textures" dialog which was added to history even when cancelled
- Fixed bug with partly hidden popmenu on Hidpi screens
- Fixed bug after deleting an element, preventing to select new elements in views
- Fixed several errors with elements list functions
- Fixed UV of inverted element
- Fixed bug with importable files format directly opened with Cubik which was displaying registration dialog
- Fixed bug with inverted down face
- Fixed bug with bad undo/redo wrongly added to history
- Fixed display bug with multiline input filed
