Error Registration  [Solved]
Re: Error Registration
Post by Bomerie » 15 Apr 2018, 21:01
I delete the folder and nothing change however i can share you the files in the folder if you want ? thanks you for the answer :D
Bomerie
Re: Error Registration  [Solved]
Post by Sphax » 16 Apr 2018, 09:45
I tested your license details (Serial + Email) and everything worked well (and I'm in France).
So please verify again the following:
1) You have downloaded latest version of Cubik Updater from this website
2) Your time and time zone are set correctly
3) You are entering valid Serial (in your case "BDC-...")
4) You are entering associated email (the one you use on that forum)
Post by andrew » 21 May 2018, 02:32
:cubik: I have the exact same problem and ive tried deleting the files and restarting and my time is correct and the code is correct and the email is correct HELP I cant figure this out
andrew
Post by andrew » 21 May 2018, 12:35
OK so this is how i fixed my problem all i did after i checked time internet email and serial. all I did was type in the serial in lower case instead of CAPS :o LOL mabey try that
andrew
