Hello, I made a small project for my map Minecraft, but I have a problem, I imported the item as an apple and it has walk I have the textures (that of stone_andesit)
and the second which is normally sandstone (I put sandstone_normal) I also try sand but nothing to do, it remains a black and purple texture
I'm linking the file for you to tell me where the problem is coming from.
thank you in advance
the link : http://www.mediafire.com/file/64qcrvaqd ... apple.json
I have a texture problem: / [Solved]
Re: I have a texture problem: / [Solved]
I am résolu the problem
Simple but effective. Map creator
