Since the Update I can't rotate my voxels.
In Germany I used Strg. I think it's the same like your Ctrl.But it doesn't work anymore.I can only rotate 90 degrees.It was no problem before the Update to rotate it what ever I want.How does it works now?
How to rotate the Voxel(not 90 degrees) [Solved]
Re: How to rotate the Voxel(not 90 degrees)
Thank you. I began to read this before, but not till the buttom, because of english is not my language.
For all who read this press 1 if you want to rotate the voxel.
