How to rotate the Voxel(not 90 degrees)  [Solved]
Post by eve2211 » 14 Mar 2018, 22:41
Since the Update I can't rotate my voxels.
In Germany I used Strg. I think it's the same like your Ctrl.But it doesn't work anymore.I can only rotate 90 degrees.It was no problem before the Update to rotate it what ever I want.How does it works now?
eve2211
Re: How to rotate the Voxel(not 90 degrees)  [Solved]
Post by Sphax » 14 Mar 2018, 22:55
Post by eve2211 » 15 Mar 2018, 06:35
Thank you. I began to read this before, but not till the buttom, because of english is not my language.
For all who read this press 1 if you want to rotate the voxel.
eve2211
Post by Sphax » 18 Mar 2018, 11:25
Not voxel but element or cuboid. ;)
