Web Pages Don't Scroll [Solved]
I'm using Firefox on OS X and none of the Cubik Studio pages scroll. Is it just me? Every other site I've checked scrolls correctly.
Re: Web Pages Don't Scroll
The website does replace the scroll bar with a JavaScript one. I suspect you've disabled JavaScript.
I have now added a check for that as currently it's just totally disabling the ability to scroll if JavaScript is off. Let me know if you're still having issues.
Still no scroll. (And this reply window is at the limit of what I can see.
) I checked in "about:config" and javascript is enabled. That doesn't seem to be the issue. I'm "Nonsanity" of Discord if you need live help resolving this.
Had to shrink the page appearance to get tot he submit button.
Okay, apparently this was because the plugin for the scrollbar just does not work on Mac due to issue with the way Mac implements its scrollbar.
I put a check in for Mac to not try to insert the custom toolbar. You might need to flush your cache.
This is a pretty good example of why overwriting basic things like scrollbars is bad practice ^.^;;
+1 for this issue. I'm on latest OSX release and this problem is present on Chrome, Firefox and Safari. Thanks in advance, HanFox!
I tried flushing cache and the problem still intermittently persists. If I do things like login, the scroll bar will come back. Whatever solution u come up with HanFox, you may want to sticky it (especially if it requires user action) so you dont have to SCROLL to see it. Natch.
Wait... Is this because OS X uses a reversed mouse wheel direction from Windows?
Re: Web Pages Don't Scroll [Solved]
No, from what I read from the plugin dev it's because Mac OS X overlays their own scrollbars instead of padding them on the side of content like Windows. I could be wrong. I've not physically used a mac since the old boxy Macintosh machines
Anyway, I removed the JS scrollbar. It's obviously just causing issues, it's no longer maintained and as browsers evolve it'll break more and cause more and more issues. Like I said, replacing basic stuff like full page scrollbars is generally considered bad practice anyway.
You might need to clear your cache to flush out the old stuff.
