When you select an element in Cubik Studio, you're able to move the selected element(s) around by a SET, small, distance through using the UP,DOWN,LEFT,RIGHT keys. Is there any way (using the current Cubik version) to move these element(s) at a lesser distance for more precise arrangements?
SIDE NOTE: I know I can right-click the selected element(s) in the element list, click "move", then enter the X/Y/Z, but I would want to use the UP,DOWN,LEFT,RIGHT arrows so I can save hours of my time.
Thanks in advanced.
Slightly moving elements via UP,DOWN,LEFT,RIGHT
- CombatBorn
- Likes: 1 x
Re: Slightly moving elements via UP,DOWN,LEFT,RIGHT
You can set the grid snap for keyboard in View > Grid
1 x
Thanks, so far so good. I noticed however that using the method only goes to 512, and sometimes the elements aren't entirely connected. Hard to tell further away, but it's a noticeable up close.
This is Halo shotgun I'm working on for a client right now:
(Almost done)
(Almost done)
- CombatBorn
- Likes: 1 x
