Hello, with a current issue for the java export around, I believe this is a great opportunity for further improvements. I have just bought this tool recently, but can't use it properly because of the linked issue. However, there were a few other things I'd like to see changed in the java exports;
- Remove the e#_ prefix of parts when exporting a entity model.
- Make element names case sensitive when exporting a minecraft entity (because "partZero" is currently exported to "Partzero")
- Make the class name of the export file case sensitive, currently "ModelXYZ" is exported to type "Modelxyz".
Thats all I noticed, thank you very much.
Improvements to java entity model export
Re: Improvements to java entity model export
1) I can't remove the "e#_" prefix because that is making unique names. 2 elements can have same name but not same ID.
2) I can keep cases in names but first letter will be capitalized
3) Same as 2
3) Same as 2
1) Not even in the exported file? I always have to remove the e#_ prefix, and the Java IDE would throw an error anyways if two elements have the same name. But this is a personal preference anyway, unlike 2) and 3), so I will just write a small script that removes the e#_ prefixes for me.
2) and 3) would make the export file follow the Java conventions (or at least not unfollow them if the user follows them), so 3) isn't too bad as the type name should always be capitalized.
I wonder how the the file is being exported if the first letter will always be capitalized. Aren't just the element strings (which can be lowercase in the editor) put into the export file during the export?
Edit: But I fully understand if the editor is in a state that would be too hard to adjust just for the java export files.
2) is kind of wrong, java convention is camelCase
And SnakeCase for Class names (alias the java file name)
Sorry if this was unclear, but that is exactly what I said. I was referring to 2) and 3) of my initial suggestion and said that his proposed fix for 3) would at least make 3) follow the java convention.
Edit: I read through your post again, it is UpperCamelCase for classes and lowerCamelCase for variables, snake_case is not used in java.
camelCase for fields/properties
CamelCase for classes.
I'll see how to respect that for next update
This one is snake case -> something_snake_case
This is upper camel case -> JavaClass
and this is lower camel case -> javaFieldOrProperty
And thanks for considering these improvements.
Meh I always mix up the names for the cases
Sorry for the mistake
