Element list order / Transparent texture issue
Post by tamanor » 27 Jan 2018, 20:43
Hi. I just got Cubik Studio yesterday and still getting used to how it works but so far I'm really liking the program.
but i was just wondering if anyone can help me I making a model which will have partial translucent texture on some of the side with another object in the center that you can see though the translucent of the main model.
I used the automatically sort transparent elements button which has worked great.
But one of the elements i want to move up in the list as it is not where i need it to be.
I have tried clicking and dragging on the elements list and that does not seem to work and I have tried right clicking to see if there is any option.
So could some one tell me how it can be done or if it is possible.
Thanks
tamanor
Re: Element list order.
Post by tamanor » 27 Jan 2018, 22:41
I did it manually in the .JSON file not sure still if there is a way to do in from the program. but it did not fix the problem i was hoping it would when i rotate the model it kinda messes up the transparency. like making facing invisible until i move the camera slightly. i have tried moving all the transparent elements to the bottom of the list like i have seen suggested in other threads but that did not fix the issue.
Image How it should look from the back
Image how it should look from the side
This is happening on all the sides depending on where I'm looking at it from.
tamanor
Re: Element list order / Transparent texture issue
Post by tamanor » 01 Feb 2018, 00:10
Can anyone help. i have tried putting the transparent parts at the top and also at the bottom of the element list and non of them fixed the issue
tamanor
