Hey at all,
I've just got an weird problem.
If I start CubikStudios it comes first in a Window with a whitescreen,
after that it disapears and I can see the CubikStudios Icon in my Taskbar,
but i can't see it on my Desktop.
If I click on it, nothing happens.
Can somebody help me out with this problem ?
- I've updatet Java shortly.
- I reinstalled CubikStudio too, even on an another hard drive
Greeting from Germany
CubikStudio won't popup (Windows 10 Pro x64) [Solved]
- Kaesekuchen212
Re: CubikStudio won't popup (Windows 10 Pro x64) [Solved]
There are a few ways to solve the issue:
- Try holding alt whilst the program is opening (white/black screen)
- Whilst the program is open select it in the taskbar then press Windows key + an arrow key
- Whilst the program is open select it in the taskbar and press Alt+Space and select "Maximize" from the menu that should appear in the top left of your screen
- Go to C:\Users\<user>\AppData\LocalLow\BDcraft\Cubik and edit cubikdata.json so that "windowX" and "windowY" are 0
Well, i've found a one step way.HanFox wrote: 06 Jan 2018, 18:26 There are a few ways to solve the issue:
I've just found it maybe one minute ago.
Just Rightklick and click on Maximize, so the Window appears,
it works for me, tho.
- Kaesekuchen212
I listed 4 ways to do it (some of which are more or less as simple as what you stated).
I don't list the way you found as some people have stated they didn't have that option for some reason.
Hm, okay, but thank you alot for helping me anyway.
- Kaesekuchen212
