missing texture  [Solved]
missing texture
Post by Falkmar » 31 Dec 2017, 17:57
I have created a ladder in 3d because I test how everything works when I did the ladder it was in 3d in the game but it is black and purple texture how do I fix this have done all I can. and I use the original ladder texture from Minecraft.
Falkmar
Re: missing texture  [Solved]
Post by Cookiesnom » 31 Dec 2017, 22:08
Check your texture path inside your ladder json, and make sure its in the right file.
If you are making a 3d ladder, your ladder model will need to be in "models/block". and if you open your models .json then the texture path should be "blocks/ladder".
Another issue that might have happened is that the file extension could be capitalised eg. ladder.PNG not ladder.png. This will cause the texture to not work.
If trying this doesn't work, then just upload the ResourcePack here and we can try and fix it!
Cookiesnom
Re: missing texture
Post by Falkmar » 01 Jan 2018, 20:02
I fixed it now. so it works now thanks for the help. :)
Falkmar
