Post
by DUELS133 » 30 Dec 2017, 19:04
Hello
, my problem is this:
When I import an .obj file that has a texture, it appears white. Before doing this topic I searched Google and the Cubik Studio forum and saw Sphax saying to check the .obj and .mtl files and according to his instructions, on other people's topics, my files are correct.
I do not know if it is necessary, but the operating system I use is OS X The Captain.
DUELS133
Post
by CaptainGalax » 31 Dec 2017, 11:51
DUELS133 wrote: 30 Dec 2017, 19:04
Hello
When I import a .obj file that has a texture, it appears white. Before doing this topic I searched Google and the Cubik Studio forum and saw Sphax saying to check the .obj and .mtl files and according to his instructions, on other people's topics, my files are correct.
Could you send your OBJ + MTL file? Maybe there's an error, the path could be wrong, or the OBJ isn't loading the mtl.
CaptainGalax
13 x | 18 x
Post
by DUELS133 » 01 Jan 2018, 19:29
CaptainGalax wrote: 31 Dec 2017, 11:51
Hello
http://www.mediafire.com/file/q95j9toi1p34bpf/Earth.zip
DUELS133
Post
by CaptainGalax » 05 Jan 2018, 13:23
DUELS133 wrote: 01 Jan 2018, 19:29
Hello
Found it!
map_Ka C:\Documents and Settings\glenn\Desktop\erth\02\4096\4096_earth.jpg <--- (Wrong Path, Earth is also missspelled)
map_Kd C:\Documents and Settings\glenn\Desktop\erth\02\4096\4096_earth.jpg <--- (Wrong Path, Earth is also missspelled)
map_Ke C:\Documents and Settings\glenn\Desktop\erth\02\4096\4096_night_lights.jpg <--- (Wrong Path, Earth is also missspelled)
map_bump C:\Documents and Settings\glenn\Desktop\erth\02\4096\4096_bump.jpg <--- (Wrong Path, Earth is also missspelled)
newmtl 02___Default
Ns 10.0000
Ni 1.5000
d 1.0000
Tr 0.0000
Tf 1.0000 1.0000 1.0000
illum 2
Ka 0.5882 0.5882 0.5882
Kd 0.5882 0.5882 0.5882
Ks 0.0000 0.0000 0.0000
Ke 0.0000 0.0000 0.0000
map_Ka C:\Documents and Settings\glenn\Desktop\erth\02\4096\4096_clouds.jpg <--- (Wrong Path, Earth is also missspelled)
map_Kd C:\Documents and Settings\glenn\Desktop\erth\02\4096\4096_clouds.jpg <--- (Wrong Path, Earth is also missspelled)
map_d C:\Documents and Settings\glenn\Desktop\erth\02\4096\4096_clouds.jpg <--- (Wrong Path, Earth is also missspelled)
CaptainGalax
13 x | 18 x
Post
by Sphax » 19 Jan 2018, 10:10
prefer editing MTL file with relative paths instead of absolute paths. So that will work better for anyone.
A lot of software do not export paths in MTL files correctly...
- Admin
70 x | 223 x
Post
by DUELS133 » 19 Jan 2018, 19:57
CaptainGalax wrote: 05 Jan 2018, 13:23
Found it!
newmtl 02___Default
Ns 10.0000
Ni 1.5000
d 1.0000
Tr 0.0000
illum 2
Sphax wrote: 19 Jan 2018, 10:10
Thanks all
DUELS133
