Post
by Itz3DPie » 31 Dec 2017, 09:20
I have been running into this issue with every block texture I made for Minecraft.
I have no idea why but any block this textured block touches goes invisible.
I really appreciate any help as I cannot seem to find a solution to this so far.
Thanks in advance!
Itz3DPie
1 x
Post
by Cookiesnom » 31 Dec 2017, 10:15
This is something to do with Minecraft its self. its called Culling, it hides the faces that aren't seen in normal play, so if you use a full block like you are, it tries to hide faces of the blocks its touching because Minecraft thinks there is a full block there. To fix this just use blocks that aren't full blocks .eg Slabs ,Stairs ,Cauldron ,Carpet. or you can use barrier block with an item frame. and make the model equal to a full block on the item frame to simulate a block!
2 x
Cookiesnom
4 x | 9 x
Post
by Itz3DPie » 31 Dec 2017, 10:59
Cookiesnom wrote: 31 Dec 2017, 10:15
Ah okay, thanks!
Everything is working fine now
Itz3DPie
1 x
Post
by CaptainGalax » 31 Dec 2017, 11:50
Or use armor stands. It's working also, and better to be honest.
CaptainGalax
13 x | 18 x
