I can't open the program. [Solved]
I opened the program but nothing happened, which is the icon in the taskbar.
- Murasaki_Hotaru
Re: I can't open the program.
It's a standard Problem.
Right click on it and choose "Maximize" that should fix it.
- CaptainGalax
- Likes: 13 x | 18 x
I'm having the same problem but I can't maximize because there is no option in Windows10 for that.
Re: I can't open the program. [Solved]
There are a few ways to solve the issue:
- Try holding alt whilst the program is opening (white/black screen)
- Whilst the program is open select it in the taskbar then press Windows key + an arrow key
- Whilst the program is open select it in the taskbar and press Alt+Space and select "Maximize" from the menu that should appear in the top left of your screen
- Go to C:\Users\<user>\AppData\LocalLow\BDcraft\Cubik and edit cubikdata.json so that "windowX" and "windowY" are 0
- Murasaki_Hotaru
