Model shows black elements and I can't figure out why...  [Solved]
Post by ThordFox » 24 Nov 2017, 12:37
I disabled ambient occlusion and shading on the model and all the elements, respectively... Still getting black parts...
It's a really simple model, just a redstone wire line. See if you can give me a hand please? :)
I attach to you my model (name is redstone_up) in .cubik and .json formats, as well as the redstone_wire.json blockstate I'm using (the vanilla one, but I guess you need all the info if you intend to download this to help me...)
redstone_wire.json
(1.79 KiB) Downloaded 279 times
redstone_up.json
(9.97 KiB) Downloaded 279 times
redstone_up.cubik
(2.87 KiB) Downloaded 346 times
ThordFox
Re: Model shows black elements and I can't figure out why...
Post by ThordFox » 03 Dec 2017, 23:00
bump
ThordFox
Re: Model shows black elements and I can't figure out why...  [Solved]
Post by Cookiesnom » 13 Dec 2017, 14:59
Wouldnt have a clue why this happens, I tested several things and nothing worked, so I just made some by extruding the red stone dust texture
Download it if you want.
RedStone.zip
(11.45 KiB) Downloaded 296 times
Cookiesnom
Post by ThordFox » 13 Dec 2017, 20:12
thank you ! I'm also clueless as to why this happens... but your models will come in handy!
ThordFox
Post by Sphax » 12 Feb 2018, 15:40
I think the black texture is due to wrong texture path in your json. That's probably the purple&black texture tinted to red which is infact displayed in your screenshots
