Cubik Serial Reset Information  [Solved]
Post by ItsBlockFighter » 28 Nov 2017, 13:10
Hi!
It would be my question that I have already activated the serial and can only use one person on a pc.
And that if I ask a reset it will change and then another person can use it?
Because I want one of my friends to use me.
ItsBlockFighter
Re: Cubik Serial Reset Information
Post by HanFox » 28 Nov 2017, 13:42
From the Terms of Use you agreed to when making the purchase:
By using Cubik Studio, you know that you ARE NOT authorized to:
  • Communicate your Serial to anyone and you are aware that if a Serial is posted on the internet, or is used by more than one user on more than one machine, it will be automatically banned and the attached product will become unusable.
if you want your friend to use Cubik Studio you would need to buy them their own a key.
Post by ItsBlockFighter » 28 Nov 2017, 13:56
This is fine, but if I reset then I would not use it back my friend yes, can that be done?
ItsBlockFighter
Cubik Serial
Post by ItsBlockFighter » 28 Nov 2017, 16:09
Hi!
It would be my problem that I still did not get the answer that Cubik Serial is reset then I will not use it but my friend yes, so I do not break the rules as a person uses a machine if I think so well.
((Sorry my bad english))
ItsBlockFighter
Post by Sphax » 28 Nov 2017, 22:20
A Serial must be used by only one user. It's not necessarily the owner who must be that user.
If you own 2 serials and only use one, you can safely share the second one with a friend (for example).
However, if that second serial is shared with more than one user, it might be disabled (automatically) as described in terms of use. ;)
Post by ItsBlockFighter » 29 Nov 2017, 14:38
Yes, I have a serial and I want my friend to use, can a serial reset be solved?
ItsBlockFighter
Re: Cubik Serial Reset Information  [Solved]
Post by HanFox » 30 Nov 2017, 12:07
Done.
Post by ItsBlockFighter » 30 Nov 2017, 15:08
Is it now reset?
ItsBlockFighter
