Problem Transferring from Cubik Pro to Cubik Studio [Solved]
I have tried to transfer my account. I have looked at the forums and followed the guide however I need the serial code from the purchase email. When I use the resend form I can't receive the email. Is there some other way?
- Endercraft
Re: Problem Transferring from Cubik Pro to Cubik Studio
The old form has issues sending emails and I have now replaced it.
Please try: https://cubik.studio/recover_key
I still don't receive the email.
- Endercraft
Did the form say it found a key or not?
It just showed the same form but blank
- Endercraft
Re: Problem Transferring from Cubik Pro to Cubik Studio [Solved]
I suspect the Javascript is cached on your PC, so I guess we'll do it the hard way.
Please send to me in a Private Message the following:
- A PayPal (or similar) receipt, or at least a relatively accurate date of purchase;
- the email addresses you likely used;
- the username you likely used;
- your real name
It worked, thanks.
- Endercraft
