Problem Transferring from Cubik Pro to Cubik Studio  [Solved]
Post by Endercraft » 25 Nov 2017, 07:20
I have tried to transfer my account. I have looked at the forums and followed the guide however I need the serial code from the purchase email. When I use the resend form I can't receive the email. Is there some other way?
Endercraft
Re: Problem Transferring from Cubik Pro to Cubik Studio
Post by HanFox » 25 Nov 2017, 10:51
The old form has issues sending emails and I have now replaced it.
Please try: https://cubik.studio/recover_key
Post by Endercraft » 25 Nov 2017, 16:32
I still don't receive the email.
Endercraft
Post by HanFox » 25 Nov 2017, 18:16
Did the form say it found a key or not?
Post by Endercraft » 26 Nov 2017, 03:59
It just showed the same form but blank
Endercraft
Re: Problem Transferring from Cubik Pro to Cubik Studio  [Solved]
Post by HanFox » 26 Nov 2017, 09:30
I suspect the Javascript is cached on your PC, so I guess we'll do it the hard way.
Please send to me in a Private Message the following:
  • A PayPal (or similar) receipt, or at least a relatively accurate date of purchase;
  • the email addresses you likely used;
  • the username you likely used;
  • your real name
Post by Endercraft » 26 Nov 2017, 15:03
It worked, thanks.
Endercraft
