Completely remove shadows  [Solved]
Post by RootPC » 11 Nov 2017, 14:15
Is there any way to completely remove shadows if a block is touching another block that has culling disabled?
I have tried disabling shadows in cubik, and disabling culling on all faces of the model, but I'm starting to believe it's hard coded into minecraft.
RootPC
Re: Completely remove shadows  [Solved]
Post by Sphax » 12 Nov 2017, 13:49
Have you tried disabling ambient occlusion on model and shade on each element?
Post by RootPC » 12 Nov 2017, 17:53
Ah! Disabling ambient occlusion did it! Thanks!
- Actually, it only worked on that specific model O_o . I've tried duplicating all the settings from that model to others, and it's not working at all :/
RootPC
