https://imgur.com/2dUikzo
HI
How can i fix this
Registration failed [Solved]
Re: Registration failed
When you don't post from your account attached to your Cubik key we can't really check what the issue is.
What's your Cubik account username?
sean1005
Re: Registration failed [Solved]
Please, verify you are entering the right email and serial in the fields and verify your OS is configured with the correct timezone and your clock is set to the right hour.
These are correct, but still not
