Failed Texture  [Solved]
Re: Failed Texture
Post by KarliosoHD » 20 Sep 2017, 15:17
I'm using the Minecraft 1.11.2 version
Sorry if have made some failures in this post, i'm not so good at english :p
KarliosoHD
Re: Failed Texture
Post by KarliosoHD » 20 Sep 2017, 15:32
Her if you can help xD I don't understand anything of this but maybe you :)
[+] Show
Unable to load definition minecraft:pink_stained_glass
java.lang.RuntimeException: Encountered an exception when loading model definition of 'minecraft:pink_stained_glass' from: 'minecraft:blockstates/pink_stained_glass.json' in resourcepack: 'Map Resourcepack 0.26-Beta'
	at cbk.a(SourceFile:308) ~[cbk.class:?]
	at cbk.a(SourceFile:293) ~[cbk.class:?]
	at cbk.a(SourceFile:282) ~[cbk.class:?]
	at cbk.b(SourceFile:206) [cbk.class:?]
	at cbk.a(SourceFile:182) [cbk.class:?]
	at cbl.a(SourceFile:23) [cbl.class:?]
	at cae.c(SourceFile:105) [cae.class:?]
	at cae.a(SourceFile:93) [cae.class:?]
	at bes.f(SourceFile:726) [bes.class:?]
	at bes.c(SourceFile:1856) [bes.class:?]
	at bes.az(SourceFile:1739) [bes.class:?]
	at bes.t(SourceFile:1626) [bes.class:?]
	at bes.av(SourceFile:970) [bes.class:?]
	at bes.a(SourceFile:398) [bes.class:?]
	at net.minecraft.client.main.Main.main(SourceFile:124) [Main.class:?]
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_25]
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_25]
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_25]
	at java.lang.reflect.Method.invoke(Method.java:483) ~[?:1.8.0_25]
	at net.minecraft.launchwrapper.Launch.launch(Launch.java:131) [launchwrapper-1.7.jar:?]
	at net.minecraft.launchwrapper.Launch.main(Launch.java:27) [launchwrapper-1.7.jar:?]
Caused by: com.google.gson.JsonParseException: Neither 'variants' nor 'multipart' found
	at brj$a.a(SourceFile:126) ~[brj$a.class:?]
	at brj$a.deserialize(SourceFile:117) ~[brj$a.class:?]
	at com.google.gson.TreeTypeAdapter.read(TreeTypeAdapter.java:58) ~[TreeTypeAdapter.class:?]
	at com.google.gson.Gson.fromJson(Gson.java:803) ~[Gson.class:?]
	at com.google.gson.Gson.fromJson(Gson.java:741) ~[Gson.class:?]
	at brj.a(SourceFile:39) ~[brj.class:?]
	at cbk.a(SourceFile:306) ~[cbk.class:?]
	... 20 more
KarliosoHD
Re: Failed Texture
Post by HanFox » 20 Sep 2017, 15:43
That to me suggests that Minecraft can't find the model called pink_stained_glass.json in the models/block folder.
Your issue is getting confusing because you haven't really explained what you've done to break everything up to this point.
You might want to post a small resourcepack that includes the files you've changed in regards to the pink glass so I can take a proper look.
Re: Failed Texture
Post by KarliosoHD » 21 Sep 2017, 12:42
I would like to send the resourcepack, but it's too large :(
KarliosoHD
Re: Failed Texture
Post by KarliosoHD » 21 Sep 2017, 16:56
I've just created a new model with wooden planks textures and rotated/moved it (In Rotations/Positions that MC should accept) saved it as .cubik file and then exported it as .JSON file into the resourcepack, then it showed the failure texture and I've written this thread... That's what I've done to break it up to this point...
KarliosoHD
Re: Failed Texture
Post by HanFox » 21 Sep 2017, 17:21
What you say seems unlikely as your model works fine.
A resourcepack which has the changed files relating to this model would be helpful.
Re: Failed Texture
Post by KarliosoHD » 22 Sep 2017, 13:35
I would like to send it, but how I've said, it's too big
KarliosoHD
Re: Failed Texture  [Solved]
Post by KarliosoHD » 12 Nov 2017, 19:07
Finally I've found the reason, sorry that I'm so stupid xD! I've put it into the blockstates folder, not the models/blocks folder, however, thx for helping :P
KarliosoHD
