Hey ppl!
i got some strungle with my first Texture and i cant find the problem!
I try to make a severtexturepack, so if a Stick has the Lore "Stab" it gets another Texture, this is working.
Now i did a Json with Cubik Studio, i Changed the properties, and it gets Purple and Black.
I checked all the Pathes so far i understand the "code".
Everytime i redo it CS is saying: "Model with unknown paths Your model uses 2 unsaved textures. To proceed, Cubik Studio exported them as PNGs beside JSON. Move all PNGs in your ResourcePack and update the JSON if necessary. if you get purple and black colors on your model in game, verify in JSON each texture path exists."
Ok done so far, all Textures are where they should be.
Cit folder has the JSON and the PNG.
Items folder (in the Cit folder) has "e_particle.png" and "e_texture.png"
i dont know these pngs and i dont know what they mean.
Thanks ppl! =)
Bye Bye
Texture doesnt work?
Re: Texture doesnt work?
Check your model is using right textures in Cubik. Leave only the texture you are actually using in Cubik Textures list.
After export check that in the Json, paths to textures are actually existing in your ResourcePack.
Be sure that no name is in uppercase in your paths.
Hey! =)
Now i think i realy tryed everything!
I figure out what mistake i made.
I Checked the Paths like you said but still, it wont work =/
Its realy hard, even because the tutorial is old aswell O.O
did you got someother tipps?
But thank you! =)
But thank you! =)
Hard to help you more just by guessing what you are doing and without actually seeing your model.
Do screenshots, post your .cubik file and/or your .json file.
