Failed Texture [Solved]
Failed Texture
I've created a steering wheel for a boat and wanted to change it with pink glass, but why ever in won't load it... all I see is the Black-Purple Failure Texture with the name of the block I used to change So I checked out for positions from the objects which Minecraft doesn't accept, but everything was fine [imgur]https://imgur.com/dwVgDOL[/imgur] can anyone say whats the fault?
Sorry if have made some failures in this post, i'm not so good at english
- KarliosoHD
Re: Failed Texture
Be sure that paths and names are in lowercases.
Otherwise hard to help you by guessing what's wrong
Re: Failed Texture
Sadly, everything is right, everything is in lowercases, and, how I said, every object is put in right, so Minecraft should acvept it
- KarliosoHD
Re: Failed Texture
Here it is
- Attachments
pink_stained_glass.json
- (12.27 KiB) Downloaded 318 times
- KarliosoHD
Re: Failed Texture
So, is there something that I've failed?
- KarliosoHD
Re: Failed Texture
Firstly pink_stained_glass.json isn't a default Minecraft model name. It's glass_pink.json.
Secondly, as can be seen below, your model works fine:
Re: Failed Texture
Hm ok... Thats a bit strange, because I've selected this name by clicking on the JSON file but how ever thank you for helping, I'll test it right now
- KarliosoHD
Re: Failed Texture
It doesn't work
I've tried it with glass_pink.json and again with pink_stained_glass.json and both won't work
how you see below, nothing happened with the model of pink glass and with pink_stained_glass.json it does make this failure again
- KarliosoHD
Re: Failed Texture
What version of Minecraft are you using? I tested in MC1.12.1.
You might want to look at your Minecraft client's log and see if any errors actually appear in there in relation to your model when it's named pink_stained_glass.json
