test  [Solved]
test
Post by Zoelisha » 03 Sep 2017, 20:47
Zoelisha
Re: Texture saving seperately from json file
Post by Zoelisha » 03 Sep 2017, 22:32
disregard
Zoelisha
Re: Texture saving seperately from json file  [Solved]
Post by Sphax » 04 Sep 2017, 17:54
If Cubik tells you that the textures you are using on model must be saved, then save them in your ResourcePack and verify that your json is actually pointing to right path for textures.
