Small lines on borders when converting from voxels to elements  [Solved]
Post by JurreKyan » 24 Aug 2017, 12:16
Small question: When I convert my voxels to elements, they all get small lines at their borders, is there a way to remove this?
JurreKyan
Re: Small lines on borders when converting from voxels to elements
Post by Sphax » 24 Aug 2017, 17:53
Post by JurreKyan » 25 Aug 2017, 11:42
Please help me, I don't understand anything of the convertion from voxels to elements. If I do Atlas or Palette, all the textures change to random colors. If I select cubes, I get all those lines on the borders of every cube. Also I start lagging while I have a gaming pc with good specs. Please help me since I need elements to use a Model animator.
JurreKyan
Post by Sphax » 25 Aug 2017, 12:00
Please post screenshots of what you get with each conversion you tried, before/after
Also, have you read the tutorial I posted above?
Post by JurreKyan » 25 Aug 2017, 12:20
I have read the tutorial, English isn't my first language so it's possible that I just didn't understand something. I will try to explain this as good as possible. So I made this moon with rocket in voxels as seen here:
You can see that it looks just fine. Now I want to convert all of the voxels to elements. From what I have heard, I have to use the atlas one. If I do that, this happens:
You see that all the textures are messed up. I thought I had to use another option so tried the cubes one. When I do that, I get all these small lines on every cube like seen here:
So.. I don't know if I don't understand it because of my English or am I just dumb?
Help would be appreciated :)
JurreKyan
Re: Small lines on borders when converting from voxels to elements  [Solved]
Post by JurreKyan » 25 Aug 2017, 14:40
Sorry I'm feeling so dumb right now. Those messed up colors are the colors of the elements -_-.
Thanks for the help, solved.
JurreKyan
