Key Usage Reset  [Solved]
Key Usage Reset
Post by NgXTruongHai » 13 Aug 2017, 13:00
Hi Sphax,
I've already purchased Cubik Studio and registered on my two PCs in two different houses. I just changed one of my PC and I couldn't register to that new PC because the key has reached the limit.
So can you reset the Key Usage? Thank you for your time.
NgXTruongHai
NgXTruongHai
Re: Key Usage Reset  [Solved]
Post by HanFox » 14 Aug 2017, 09:25
Done.
Re: Key Usage Reset
Post by NgXTruongHai » 14 Aug 2017, 10:39
HanFox wrote: 14 Aug 2017, 09:25Done.
I tried...
NgXTruongHai
Re: Key Usage Reset
Post by HanFox » 14 Aug 2017, 11:02
Verify you are entering right email and serial in fields and verify your OS is configured with correct timezone and your clock is set to right hour.
Re: Key Usage Reset
Post by NgXTruongHai » 14 Aug 2017, 11:18
it works! Thanks for your help!
NgXTruongHai
