HELp with glitch  [Solved]
HELp with glitch
Post by Zoelisha » 31 Jul 2017, 09:39
hello I use cubik alot and suddenly it says liscence has an error so I went into downloads and reput in the key but it still says its contains one or more errors??
Zoelisha
Re: HELp with glitch
Post by Sphax » 31 Jul 2017, 13:01
Please, verify that your OS has right timezone and clock is setup correctly
Post by Zoelisha » 31 Jul 2017, 16:44
Yes! It is and I'm on a time crunch my professor is going to kill me if I don't turn this in by 3 pm! What should I do?
Zoelisha
Post by Sphax » 01 Aug 2017, 17:02
What is the error exactly?
Post by Zoelisha » 02 Aug 2017, 00:53
it says you have one or more errors in your login key/registration key or whatever you use to login.
Zoelisha
Post by Zoelisha » 02 Aug 2017, 00:55
IM SURE its correct, I copied and pasted
Zoelisha
Could you like reset my key or something or give me a new one because it just wont work and I'm so behind in class
Zoelisha
Post by Sphax » 03 Aug 2017, 12:52
I need a screenshot of the error please, so I can see exactly what is happening.
Re: HELp with glitch  [Solved]
Post by Zoelisha » 03 Aug 2017, 20:47
its fixed thank you!
Zoelisha
