HELp with glitch [Solved]
HELp with glitch
hello I use cubik alot and suddenly it says liscence has an error so I went into downloads and reput in the key but it still says its contains one or more errors??
Re: HELp with glitch
Please, verify that your OS has right timezone and clock is setup correctly
Yes! It is and I'm on a time crunch my professor is going to kill me if I don't turn this in by 3 pm! What should I do?
What is the error exactly?
it says you have one or more errors in your login key/registration key or whatever you use to login.
IM SURE its correct, I copied and pasted
Could you like reset my key or something or give me a new one because it just wont work and I'm so behind in class
I need a screenshot of the error please, so I can see exactly what is happening.
Re: HELp with glitch [Solved]
its fixed thank you!
