Voxel tool paint bug
Post by SpellSw0rd » 22 Jul 2017, 03:33
When using the voxel tool after switching between brushes like dot or line, the next time I wan't to remove a voxel pixel or cube the tool thinks im trying to paint it instead of removing it. This can be very annoying as the only way to fix it is to save and reload cubik stuido over and over again.
SpellSw0rd
Re: Voxel tool paint bug
Post by Sphax » 26 Jul 2017, 14:36
Left click is using "left color"
Right click is using "right color"
You can change left and right color with color picker or color selector tools. If color is transparent, then the clicked voxel(s) will be removed but if color is not transparent (right color is transparent by default), then you'll paint instead of removing voxels.
