I'm making a 3D model for a mod that I'm making, and I'm using a reference image for it. But when I import the reference image, it gets squished into a square.
Thanks for your help!
Reference image gets squished!
- DeathBringer0007
Re: Reference image gets squished!
Pad your image with transparency to make it square so it doesn't get squished when it's imported.
The problem is, I need it to be big for the weapon I'm making.HanFox wrote: 25 Jul 2017, 01:39 Pad your image with transparency to make it square so it doesn't get squished when it's imported.
- DeathBringer0007
Are you talking about background image which is not big enough?
If so, you can import PNG as billboard and then move and resize it however you want.
