Cant see texture [Solved]
Cant see texture
I put in the texture for the top and I can't see it. It's like it doesn't render it. By the way i'm sorry i'm new to this. Thanks
Re: Cant see texture [Solved]
You defined 6 textures in "Elements Material" so you need to set the element use those textures.
A fast way is to go in "Elements list" > ... > Textures > Down, Up, North, South, West, East
Thank you very much!Sphax wrote: 23 Jun 2017, 21:45 You defined 6 textures in "Elements Material" so you need to set the element use those textures.
