Rotating an element/ elements by 90 degrees breaks rotation?
Post by rafradek » 08 Feb 2017, 22:18
I have a model that contains elements that are rotated by 45 degrees. Once i had to rotate the model by 90 degrees. The problem is, that those 45 degrees rotations reset when doing that. Is there a way to prevent this behavior?
rafradek
Re: Rotating an element/ elements by 90 degrees breaks rotation?
Post by Sphax » 13 Feb 2017, 09:07
90° Rotations of whole model do not support yet rotated elements. It's a known issue. Sorry for that.
Post by rafradek » 13 Jun 2017, 18:16
Sphax pls, it has been a long time since the last update and the rotating multiple previously rotated elements issue is still not fixed.
rafradek
