[fixed]after last updait none of my models wil export good
Post by phoxyboy » 12 Jun 2017, 14:36
all my old models exported goed but now they wont.
i have made 3 models after the updait and when i export it for minecraft. they ar a 1 block with purpel and black. if i load my old models they wil export normaly. what can be the problem?
phoxyboy
Re: after last updait none of my models wil export good
Post by Sphax » 13 Jun 2017, 20:39
attach the .cubik files here and I'll have a look.
You can also attach here the exported JSON so we could see if somewhere went wrong with json export.
Without none of that, nobody can help
Post by phoxyboy » 14 Jun 2017, 08:40
this are the models
the old model
freefall model.cubik
(4.71 KiB) Downloaded 349 times
the new model
magicgarden.cubik
(9.6 KiB) Downloaded 358 times
tnx for reminding me @sphax
phoxyboy
Post by Sphax » 17 Jun 2017, 06:57
In what format do you try to export?
Post by Sphax » 17 Jun 2017, 07:04
The model "freefall" works perfectly (after you fixed a freely rotated element) but the model "magicgarden" doesn't work because some elements are out of boundaries. Minecraft is not precise about out of bounds and does not take in account rotated elements.
So if an element with angle is out of bound without that angle, the whole model model will not load, creating that purple block.
Post by phoxyboy » 19 Jun 2017, 13:35
Sphax wrote: 17 Jun 2017, 07:04 The model "freefall" works perfectly (after you fixed a freely rotated element) but the model "magicgarden" doesn't work because some elements are out of boundaries. Minecraft is not precise about out of bounds and does not take in account rotated elements.
first i was thinking that to but i just made a 1 blok model and having the same problem the blok was 1 pixel at all sides smaller.
the file
test.cubik
(1.62 KiB) Downloaded 306 times
in game
Sphax wrote: 17 Jun 2017, 06:57 In what format do you try to export?
into a .JSON file
idk what i am doing wrong.
phoxyboy
