Hello everyone, I need your help.
I created a model of a book and I used a texture to create the pages.
Now I have two textures: one for the whole book and one for the pages, but to import this model to minecraft I have to use just a texture, how can I unit them?
I need your help with a model [Solved]
Re: I need your help with a model
Minecraft can totally use 2 textures for one model for blocks or items.
However if you want to use only one texture, you just have to copy/paste the used part(s) of your second texture in first texture, then edit elements to use first texture and finally modify UV mapping so each face uses right part of modified first texture.
1 x
So how can I do that with these textures?
First texture: http://imgur.com/a/j479b
Second texture: http://imgur.com/vHklG2Y
Re: I need your help with a model [Solved]
First texture looks like generated after conversion of voxels to elements and second from one or more elements you added.
To combine both you can use Material Manager > ... > Create Atlas (keep textures)
That will generate a new texture with all elements in. Before that, you should optimize elements first (so hidden faces would be removed and some place would be saved in generated texture).
