Pink Box  [Solved]
Pink Box  [Solved]
Post by Cam_Z_Tec » 05 Jun 2017, 01:09
Hello! I just recently bought Cubik studio and i have made a really time consuming model. The model is for a diamond hoe and will not appear in game. It shows up as a pink huge box. Before i exported this model i had a error where it told me to put the model in the bounding box. I rotated the model to make it fit. so then i tried again no luck :( Here is the model json
	"__comment": "Designed by Cam_Z_Tec with Cubik Studio - https://cubik.studio",
	"textures": {
		"texture": "blocks/anvil_base",
		"texture1": "blocks/wool_colored_black",
		"texture2": "blocks/hardened_clay_stained_cyan",
		"texture3": "blocks/glass_light_blue",
		"texture4": "blocks/coal_block"
	"elements": [
			"__comment": "Cube2",
			"from": [ 7, 7, 5 ],
			"to": [ 10, 10, 14 ],
			"rotation": { "origin": [ 7, 7, 5 ], "axis": "y", "angle": 45 },
			"faces": {
				"down": { "uv": [ 7, 2, 10, 11 ], "texture": "#texture" },
				"up": { "uv": [ 7, 5, 10, 14 ], "texture": "#texture" },
				"north": { "uv": [ 6, 6, 9, 9 ], "texture": "#texture" },
				"south": { "uv": [ 7, 6, 10, 9 ], "texture": "#texture" },
				"west": { "uv": [ 5, 6, 14, 9 ], "texture": "#texture" },
				"east": { "uv": [ 2, 6, 11, 9 ], "texture": "#texture" }
			"__comment": "Cube3",
			"from": [ 9, 8, 14 ],
			"to": [ 9.5, 9, 35.5 ],
			"faces": {
				"down": { "uv": [ 9, 0, 9.5, 2 ], "texture": "#texture", "cullface": "south" },
				"up": { "uv": [ 9, 14, 9.5, 16 ], "texture": "#texture", "cullface": "south" },
				"south": { "uv": [ 9, 7, 9.5, 8 ], "texture": "#texture", "cullface": "south" },
				"west": { "uv": [ 14, 7, 16, 8 ], "texture": "#texture", "cullface": "south" },
				"east": { "uv": [ 0, 7, 2, 8 ], "texture": "#texture", "cullface": "south" }
			"from": [ 7.5, 8, 14 ],
			"to": [ 8, 9, 35.5 ],
			"faces": {
				"down": { "uv": [ 10.5, 0, 11, 2 ], "texture": "#texture", "cullface": "south" },
				"up": { "uv": [ 10.5, 14, 11, 16 ], "texture": "#texture", "cullface": "south" },
				"south": { "uv": [ 10.5, 7, 11, 8 ], "texture": "#texture", "cullface": "south" },
			"from": [ 8, 9, 14 ],
			"to": [ 9, 9.5, 35.5 ],
			"faces": {
				"down": { "uv": [ 0, 7, 2, 8 ], "texture": "#texture", "cullface": "south", "rotation": 90 },
				"up": { "uv": [ 16, 8, 14, 7 ], "texture": "#texture", "cullface": "south", "rotation": 270 },
				"south": { "uv": [ 9, 7, 9.5, 8 ], "texture": "#texture", "cullface": "south", "rotation": 90 },
				"west": { "uv": [ 9, 0, 9.5, 2 ], "texture": "#texture", "cullface": "south", "rotation": 90 },
				"east": { "uv": [ 9.5, 16, 9, 14 ], "texture": "#texture", "cullface": "south", "rotation": 270 }
			"from": [ 8, 7.5, 14 ],
			"to": [ 9, 8, 35.5 ],
			"faces": {
			"__comment": "Cube10",
			"from": [ 8, 3, 0 ],
			"to": [ 9, 7, 5 ],
			"faces": {
				"down": { "uv": [ 8, 11, 9, 16 ], "texture": "#texture4" },
				"up": { "uv": [ 8, 0, 9, 5 ], "texture": "#texture4" },
				"north": { "uv": [ 7, 9, 8, 13 ], "texture": "#texture4", "cullface": "north" },
				"south": { "uv": [ 8, 9, 9, 13 ], "texture": "#texture4" },
				"west": { "uv": [ 0, 9, 5, 13 ], "texture": "#texture4" },
				"east": { "uv": [ 11, 9, 16, 13 ], "texture": "#texture4" }
			"__comment": "Cube11",
			"from": [ 8, 4, 6 ],
			"to": [ 9, 7, 7 ],
			"faces": {
				"down": { "uv": [ 8, 9, 9, 10 ], "texture": "#texture" },
				"north": { "uv": [ 7, 9, 8, 12 ], "texture": "#texture" },
				"south": { "uv": [ 8, 9, 9, 12 ], "texture": "#texture" },
				"west": { "uv": [ 6, 9, 7, 12 ], "texture": "#texture" },
				"east": { "uv": [ 9, 9, 10, 12 ], "texture": "#texture" }
			"from": [ 8, 4, 7 ],
			"to": [ 9, 5, 10 ],
			"faces": {
				"down": { "uv": [ 8, 9, 9, 12 ], "texture": "#texture" },
				"up": { "uv": [ 8, 12, 7, 9 ], "texture": "#texture" },
				"west": { "uv": [ 6, 9, 7, 12 ], "texture": "#texture", "rotation": 90 },
				"east": { "uv": [ 9, 9, 10, 12 ], "texture": "#texture", "rotation": 270 }
			"from": [ 8, 4, 10 ],
			"to": [ 9, 7, 11 ],
			"faces": {
			"__comment": "Cube32",
			"from": [ 7, 7, 0 ],
			"to": [ 9, 8, 5 ],
			"faces": {
				"down": { "uv": [ 7, 11, 9, 16 ], "texture": "#texture" },
				"up": { "uv": [ 7, 0, 9, 5 ], "texture": "#texture" },
				"north": { "uv": [ 7, 8, 9, 9 ], "texture": "#texture", "cullface": "north" },
				"west": { "uv": [ 0, 8, 5, 9 ], "texture": "#texture" },
				"east": { "uv": [ 11, 8, 16, 9 ], "texture": "#texture" }
			"from": [ 9, 7, 0 ],
			"to": [ 10, 10, 5 ],
			"faces": {
				"down": { "uv": [ 7, 11, 8, 16 ], "texture": "#texture" },
				"up": { "uv": [ 7, 0, 8, 5 ], "texture": "#texture" },
				"north": { "uv": [ 8, 6, 9, 9 ], "texture": "#texture", "cullface": "north" },
				"west": { "uv": [ 0, 6, 5, 9 ], "texture": "#texture" },
				"east": { "uv": [ 11, 6, 16, 9 ], "texture": "#texture" }
			"__comment": "Cube13",
			"from": [ 8.5, 9, 0 ],
			"to": [ 9, 10, 5 ],
			"faces": {
				"down": { "uv": [ 8, 0, 8.5, 5 ], "texture": "#texture", "rotation": 180 },
				"up": { "uv": [ 8, 11, 8.5, 16 ], "texture": "#texture", "rotation": 180 },
				"north": { "uv": [ 8, 5, 7.5, 4 ], "texture": "#texture" },
				"south": { "uv": [ 8.5, 5, 8, 4 ], "texture": "#texture" },
				"west": { "uv": [ 11, 4, 16, 5 ], "texture": "#texture", "rotation": 180 },
				"east": { "uv": [ 0, 4, 5, 5 ], "texture": "#texture", "rotation": 180 }
			"from": [ 8, 8, 0 ],
			"to": [ 9, 9, 5 ],
			"faces": {
				"down": { "uv": [ 8, 11, 9, 16 ], "texture": "#texture1" },
				"up": { "uv": [ 8, 0, 9, 5 ], "texture": "#texture1" },
				"north": { "uv": [ 7, 7, 8, 8 ], "texture": "#texture1" },
				"south": { "uv": [ 8, 7, 9, 8 ], "texture": "#texture1" },
				"west": { "uv": [ 0, 7, 5, 8 ], "texture": "#texture1" },
				"east": { "uv": [ 11, 7, 16, 8 ], "texture": "#texture1" }
			"__comment": "Cube16",
			"from": [ 6, 8, 0 ],
			"to": [ 8, 9, 1 ],
			"faces": {
				"down": { "uv": [ 6, 15, 8, 16 ], "texture": "#texture1" },
				"up": { "uv": [ 6, 0, 8, 1 ], "texture": "#texture1" },
				"north": { "uv": [ 8, 7, 10, 8 ], "texture": "#texture1" },
				"south": { "uv": [ 6, 7, 8, 8 ], "texture": "#texture1" },
				"west": { "uv": [ 0, 7, 1, 8 ], "texture": "#texture1" },
				"east": { "uv": [ 15, 7, 16, 8 ], "texture": "#texture1" }
			"__comment": "Cube17",
			"from": [ 4, 8, -1 ],
			"to": [ 6, 10, 1 ],
			"faces": {
				"down": { "uv": [ 4, 15, 6, 16 ], "texture": "#texture1" },
				"up": { "uv": [ 4, 0, 6, 1 ], "texture": "#texture1" },
				"north": { "uv": [ 10, 6, 12, 8 ], "texture": "#texture1" },
				"south": { "uv": [ 4, 6, 6, 8 ], "texture": "#texture1" },
				"west": { "uv": [ 0, 6, 1, 8 ], "texture": "#texture1" },
				"east": { "uv": [ 15, 6, 16, 8 ], "texture": "#texture1" }
			"__comment": "Cube18",
			"from": [ 7, 6, -6 ],
			"to": [ 10, 10, 0 ],
			"faces": {
				"down": { "uv": [ 7, 0, 10, 6 ], "texture": "#texture" },
				"up": { "uv": [ 7, 10, 10, 16 ], "texture": "#texture" },
				"north": { "uv": [ 6, 6, 9, 10 ], "texture": "#texture" },
				"south": { "uv": [ 7, 6, 10, 10 ], "texture": "#texture" },
				"west": { "uv": [ 10, 6, 16, 10 ], "texture": "#texture" },
				"east": { "uv": [ 0, 6, 6, 10 ], "texture": "#texture" }
			"__comment": "Cube19",
			"from": [ 8, 10, -1 ],
			"to": [ 10, 11, 1 ],
			"faces": {
				"down": { "uv": [ 8, 15, 10, 16 ], "texture": "#texture" },
				"up": { "uv": [ 8, 0, 10, 1 ], "texture": "#texture" },
				"north": { "uv": [ 6, 5, 8, 6 ], "texture": "#texture" },
				"south": { "uv": [ 8, 5, 10, 6 ], "texture": "#texture" },
				"west": { "uv": [ 0, 5, 1, 6 ], "texture": "#texture" },
				"east": { "uv": [ 15, 5, 16, 6 ], "texture": "#texture" }
			"from": [ 8, 10, 5 ],
			"to": [ 10, 11, 7 ],
			"faces": {
				"down": { "uv": [ 8, 0, 9, 1 ], "texture": "#texture" },
				"up": { "uv": [ 8, 15, 9, 16 ], "texture": "#texture" },
				"north": { "uv": [ 7, 5, 8, 6 ], "texture": "#texture" },
				"south": { "uv": [ 8, 5, 9, 6 ], "texture": "#texture" },
				"west": { "uv": [ 15, 5, 16, 6 ], "texture": "#texture" },
				"east": { "uv": [ 0, 5, 1, 6 ], "texture": "#texture" }
			"__comment": "Cube21",
			"from": [ 8, 11, -2 ],
			"to": [ 10, 12, 13 ],
			"faces": {
				"down": { "uv": [ 8, 3, 10, 16 ], "texture": "#texture" },
				"up": { "uv": [ 8, 0, 10, 13 ], "texture": "#texture" },
				"north": { "uv": [ 6, 4, 8, 5 ], "texture": "#texture" },
				"south": { "uv": [ 8, 4, 10, 5 ], "texture": "#texture" },
				"west": { "uv": [ 0, 4, 13, 5 ], "texture": "#texture" },
				"east": { "uv": [ 3, 4, 16, 5 ], "texture": "#texture" }
			"from": [ 7, 12, -2 ],
			"to": [ 8, 14, 13 ],
			"faces": {
				"down": { "uv": [ 8, 6, 9, 16 ], "texture": "#texture" },
				"up": { "uv": [ 8, 0, 9, 10 ], "texture": "#texture" },
				"north": { "uv": [ 7, 4, 8, 5 ], "texture": "#texture" },
				"south": { "uv": [ 8, 4, 9, 5 ], "texture": "#texture" },
				"west": { "uv": [ 0, 4, 10, 5 ], "texture": "#texture" },
				"east": { "uv": [ 6, 9, 16, 7 ], "texture": "#texture" }
			"from": [ 10, 12, -2 ],
			"to": [ 11, 14, 13 ],
			"faces": {
				"north": { "uv": [ 13.5, 0, 14.5, 2 ], "texture": "#texture" },
				"south": { "uv": [ 8, 4, 9, 6 ], "texture": "#texture" },
				"east": { "uv": [ 6, 7, 16, 9 ], "texture": "#texture" }
			"from": [ 8, 14, -2 ],
			"to": [ 10, 15, 13 ],
			"faces": {
				"down": { "uv": [ 8, 6, 10, 16 ], "texture": "#texture" },
				"up": { "uv": [ 8, 0, 10, 10 ], "texture": "#texture" },
				"east": { "uv": [ 6, 4, 16, 5 ], "texture": "#texture" }
			"__comment": "Cube26",
			"from": [ 8, 7.2898, -3.5391 ],
			"to": [ 9, 9.289799, -2.5391 ],
			"faces": {
				"down": { "uv": [ 4, 2, 5, 3 ], "texture": "#texture1" },
				"up": { "uv": [ 4, 13, 5, 14 ], "texture": "#texture1" },
				"north": { "uv": [ 10.5, 9.5, 11.5, 11.5 ], "texture": "#texture1" },
				"south": { "uv": [ 4, 11, 5, 13 ], "texture": "#texture1" },
				"west": { "uv": [ 13, 11, 14, 13 ], "texture": "#texture1" },
				"east": { "uv": [ 2, 11, 3, 13 ], "texture": "#texture1" }
			"__comment": "Cube25",
			"from": [ 8, 7, -14 ],
			"to": [ 9, 9, -6 ],
			"faces": {
				"down": { "uv": [ 8, 6, 9, 14 ], "texture": "#texture2" },
				"up": { "uv": [ 8, 2, 9, 10 ], "texture": "#texture2" },
				"north": { "uv": [ 7, 7, 8, 9 ], "texture": "#texture2" },
				"south": { "uv": [ 8, 7, 9, 9 ], "texture": "#texture2" },
				"west": { "uv": [ 2, 7, 10, 9 ], "texture": "#texture2" },
				"east": { "uv": [ 6, 7, 14, 9 ], "texture": "#texture2" }
			"from": [ 7, 10, -15 ],
			"to": [ 10, 11, -12 ],
			"faces": {
				"down": { "uv": [ 7, 12, 10, 15 ], "texture": "#texture" },
				"up": { "uv": [ 7, 1, 10, 4 ], "texture": "#texture" },
				"north": { "uv": [ 6, 5, 9, 6 ], "texture": "#texture" },
				"south": { "uv": [ 7, 5, 10, 6 ], "texture": "#texture" },
				"west": { "uv": [ 1, 5, 4, 6 ], "texture": "#texture" },
				"east": { "uv": [ 12, 5, 15, 6 ], "texture": "#texture" }
			"__comment": "Cube27",
			"from": [ 7, 6, -16 ],
			"to": [ 10, 10, -14 ],
			"faces": {
				"down": { "uv": [ 7, 14, 10, 16 ], "texture": "#texture" },
				"up": { "uv": [ 7, 0, 10, 2 ], "texture": "#texture" },
				"west": { "uv": [ 0, 6, 2, 10 ], "texture": "#texture" },
				"east": { "uv": [ 14, 6, 16, 10 ], "texture": "#texture" }
			"__comment": "Cube28",
			"from": [ 8, 12, -2 ],
			"to": [ 10, 14, -1 ],
			"faces": {
				"down": { "uv": [ 8, 1, 10, 2 ], "texture": "#texture3" },
				"up": { "uv": [ 8, 14, 10, 15 ], "texture": "#texture3" },
				"north": { "uv": [ 4, 14, 6, 16 ], "texture": "#texture3" },
				"south": { "uv": [ 8.5, 0, 10.5, 2 ], "texture": "#texture3" },
				"west": { "uv": [ 14, 2, 15, 4 ], "texture": "#texture3" },
				"east": { "uv": [ 1, 2, 2, 4 ], "texture": "#texture3" }
			"from": [ 8, 12, 12 ],
			"to": [ 10, 14, 13 ],
			"faces": {
				"down": { "uv": [ 8, 5.5, 10, 6.5 ], "texture": "#texture3" },
				"north": { "uv": [ 6, 2, 8, 4 ], "texture": "#texture3" },
				"south": { "uv": [ 9, 0, 11, 2 ], "texture": "#texture3" },
				"west": { "uv": [ 12.5, 5.5, 13.5, 7.5 ], "texture": "#texture3" },
	"display": {
		"thirdperson_righthand": {
			"rotation":  [ 0, 140, 0 ],
			"translation":  [ 1.35, 0.0002, 0.6956 ],
			"scale":  [ 0.5, 0.5, 0.5 ]
		"thirdperson_lefthand": {
			"rotation":  [ 0, -141, 0 ],
			"translation":  [ -1.35, 0.0002, 0.6956 ],
		"firstperson_righthand": {
			"translation":  [ 0.3913, 1.3913, -8.347 ]
		"firstperson_lefthand": {
			"rotation":  [ 0, -140, 0 ],
			"translation":  [ -3.086, 1.3913, -8.357 ]
		"gui": {
			"rotation":  [ 128, 137, -107 ],
			"translation":  [ 0.695, 0.6956, 0.6953 ],
			"scale":  [ 0.3, 0.3, 0.3 ]
		"head": {
			"rotation":  [ -42, 13, -45 ],
			"translation":  [ 0, 11.5, 0 ]
		"ground": {
			"translation":  [ -1.8, 3, 0 ],
		"fixed": {
			"rotation":  [ 59, -136, 91 ],
			"translation":  [ 0, 0, -2.782 ],
			"scale":  [ 0.4, 0.4, 0.4 ]
Pls Help :)
Cam_Z_Tec
Re: Pink Box
Post by HanFox » 05 Jun 2017, 06:53
Rotating is not the same as making it fit in the bounding box.
Minecraft works by going "this element starts at x and finish at y". Rotations are then applied after that.
In your JSON no number for "from" or "to" should be lower than -16 or higher than 32.
So, whilst unrotated, you need to make your model fit inside the grid.
Re: Pink Box
Post by Sphax » 05 Jun 2017, 09:40
for items, be sure to create your model inside the middle zone (and not in the whole available space). To make your model fit inside the middle zone (or at least fit inside world bounding box), you can use the Scale command from Elements manager.
Re: Pink Box
Post by Cam_Z_Tec » 05 Jun 2017, 22:07
Thank you very much! Best humans ever :)
Cam_Z_Tec
