Post
by Xlis1 » 31 May 2017, 08:21
I have a model that im planing on animating using the method described in the first part of this video (
https://www.youtube.com/watch?v=9EXrHIB ... RW&index=8) however i cant get my UV maps right as the second and third animation textures are down below the UV map windows view. Is there a scroll bar im missing or something to reach down there? or is it just broken? (i noticed a horizontal scroll bar for wide textures but there doesn't seem to be a vertical one
my texture is 3x36)
EDIT: it appears to be because your program assumes the width is the same as the height, to fix this just dont reuse the width variable to set the scrollbar length.
Xlis1
Post
by Sphax » 01 Jun 2017, 14:02
I reproduced the bug. It should be fixed in 2.7
- Admin
70 x | 223 x
