Saving Error
- FruitPolos
Re: Saving Error
Thank you for respond to my forum post I must say, I'm not sure what version of it, it was downloaded as of 5/6/17, so whatever version that was for Window 10. I used it to develop texture for a server a work for.
- FruitPolos
Re: Saving Error
the Cubik version and the build number is in Help > About
Please, can you send me the .CUBIK file so I can check what is happening?
Re: Saving Error
Version 2.6.384 Beta and I cant send you any files I haven't been able to send any
- FruitPolos
Re: Saving Error
Save your model as CUBIK file then in your post, attach the .cubik file you saved earlierFruitPolos wrote: 22 May 2017, 17:45 Version 2.6.384 Beta and I cant send you any files I haven't been able to send any
EDIT: Also, I see the path in the error is weird. Are you trying to save the file directly on a distant computer or hdd via network? If so, that's possible Cubik does not support that. In that, case save your file locally first and then move it over network via your OS directly.
Re: Saving Error
on a computer, and i can't save ****. I am using a crapping computer and may just download it on a different one.
- FruitPolos
Re: Saving Error
It looks like the folder you selected can't be used as a save destination. It probably is special
Re: Saving Error
How would I select a file for the proper destination, its something with the direct as seen in the error log. I'll continue working on it.
- FruitPolos
