Saving Error
Saving Error
Post by FruitPolos » 05 May 2017, 18:31
I get the following error when attempting to save a part file
FruitPolos
Re: Saving Error
Post by Sphax » 08 May 2017, 14:45
in what format?
What version of Cubik do you have?
Re: Saving Error
Post by FruitPolos » 09 May 2017, 21:01
Thank you for respond to my forum post I must say, I'm not sure what version of it, it was downloaded as of 5/6/17, so whatever version that was for Window 10. I used it to develop texture for a server a work for.
FruitPolos
Re: Saving Error
Post by Sphax » 18 May 2017, 18:50
the Cubik version and the build number is in Help > About
Please, can you send me the .CUBIK file so I can check what is happening?
Re: Saving Error
Post by FruitPolos » 22 May 2017, 17:45
Version 2.6.384 Beta and I cant send you any files I haven't been able to send any
FruitPolos
Re: Saving Error
Post by Sphax » 22 May 2017, 18:21
FruitPolos wrote: 22 May 2017, 17:45 Version 2.6.384 Beta and I cant send you any files I haven't been able to send any
Save your model as CUBIK file then in your post, attach the .cubik file you saved earlier
EDIT: Also, I see the path in the error is weird. Are you trying to save the file directly on a distant computer or hdd via network? If so, that's possible Cubik does not support that. In that, case save your file locally first and then move it over network via your OS directly.
Re: Saving Error
Post by FruitPolos » 25 May 2017, 13:22
on a computer, and i can't save ****. I am using a crapping computer and may just download it on a different one.
FruitPolos
Re: Saving Error
Post by Sphax » 25 May 2017, 16:22
It looks like the folder you selected can't be used as a save destination. It probably is special
Re: Saving Error
Post by FruitPolos » 26 May 2017, 14:52
How would I select a file for the proper destination, its something with the direct as seen in the error log. I'll continue working on it.
FruitPolos
Re: Saving Error
Post by Sphax » 26 May 2017, 16:40
What is "\file5.ad.lake.stark.k12.oh.us\shd\" ?
