1+ elements per surface (atlas) makes the texture weird and transparent  [Solved]
Post by MrGarretto » 18 Apr 2017, 22:59
Before converting to elements using the atlas method:
After converting:
And the texture that it generates reflects this
Am I doing something wrong or is this a bug?
MrGarretto
Re: 1+ elements per surface (atlas) makes the texture weird and transparent
Post by Sphax » 08 May 2017, 16:02
I would need the .cubik file with voxels (before conversion) to investigate.
That might be a bug with colors
Post by MrGarretto » 09 May 2017, 01:25
Ok, here is the .cubik file
policecar.cubik
(3.94 MiB) Downloaded 342 times
MrGarretto
Re: 1+ elements per surface (atlas) makes the texture weird and transparent  [Solved]
Post by Sphax » 18 May 2017, 18:31
This will be fixed in 2.7
In the meantime, you can fix colors yourself by setting manually the 2 last digits of each color to "ff" with the color picker and magic wand tools
Post by MrGarretto » 19 May 2017, 00:27
Thanks! :)
MrGarretto
Post by MrGarretto » 21 May 2017, 01:45
Sphax wrote: 18 May 2017, 18:31 This will be fixed in 2.7
Could you possibly give me an ETA of 2.7? I tried your temporary workaround but it's not feasible for my project because of the large amount of models I have to deal with
MrGarretto
Post by Sphax » 22 May 2017, 13:35
2.7 should be released next month (June)
