Item getting darking if your looking up
Post by epicskymi » 03 Nov 2016, 06:16
Anyone know why this is happening? the item gets darker the higher your cursor is
Looking down
Looking up
Also why doesn't cubik studio save preview settings?
epicskymi
Re: Item getting darking if your looking up
Post by Sphax » 03 Nov 2016, 07:44
You can fix the darker light (which is a bug in Minecraft) by disabling shading on all elements (you can do that in elements manager).
What do you mean by not saved display settings? In .cubik format?
Post by epicskymi » 03 Nov 2016, 08:30
ye I save the project in .cubik but when I reopen it all the display settings are default again
epicskymi
Post by epicskymi » 03 Nov 2016, 08:41
Also "shade": false, in the json file its still happening
epicskymi
Post by epicskymi » 03 Nov 2016, 17:00
I should add this is using damage models for a diamond hoe if that helps solve this issue
epicskymi
Post by Sphax » 03 Nov 2016, 17:07
This is probably a bug (or a missing implementation)
Post by epicskymi » 04 Nov 2016, 04:38
Ye idono why its doing this light to dark issue Iv disabled shading and it still happens :/
epicskymi
Post by Vexilius » 04 Nov 2016, 08:12
Make sure to turn Ambient Occlusion in the model to false.
I'm not going to guarantee results, but you never know.
Vexilius
Post by epicskymi » 04 Nov 2016, 15:02
Ill try that when I find the setting
epicskymi
Post by epicskymi » 05 Nov 2016, 16:33
Just tested disabling Ambient Occlusion nothing changed still doing the same thing
epicskymi
