BDCraft studio error  [Solved]
Post by Fancepants » 07 Apr 2017, 13:53
I am having the same issue and I verified everything. Not sure what the last link is supposed to do. I have the latest version because I just re-downloaded it. I can't access the last URL link though.
error 400 - Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/ Safari/537.36 -
Fancepants
Re: BDCraft studio error
Post by Fancepants » 07 Apr 2017, 13:55
I tried it on my Work Computer and my At home computer. It must be an issue with the actual license?
Fancepants
BD Cubic Error
Post by Fancepants » 07 Apr 2017, 20:20
I just made a model and spent about 6 hours working on it. I saved it and closed the application. I came back 1 hour later to open the file and it gives this error. :o
Cubik also says it needs updating. When I check update it states it is already updated and continues on that pop up loop.
I really need this error fixed to open this file. :cry:
I also have this license on my work computer and my home computer. Due to re imaging the home computer 2 times I needed to reinstall it again. Its having an issue with the license. Stating error with license. I went through the troubleshooting in previous posts and everything was correct. The last option to click on the link however it would not work and came up with an error. Please assist.
Shield.cubik
This is the file that will not open
(66.56 KiB) Downloaded 296 times
Fancepants
Re: BD Cubic Error
Post by Fancepants » 07 Apr 2017, 20:33
Also your checklist
1: CHECK, i used latest download
2: CHECK, clock is fine in right country
3: CHECK, has always been in lowercase when entering it in
4: CHECK, i copied the serial exactly
5: CHECK, i did paste them in the right fields
6: WARNING, i cant access that URl, here is the error when seeing the site:
error 400 - Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/57.0.2987.133 Safari/537.36 - 68.11.186.187
Fancepants
Re: BDCraft studio error  [Solved]
Post by Sphax » 11 Apr 2017, 17:40
Try deleting folder located here:
%appdata%\..\LocalLow\BDcraft\Cubik
Then restart Cubik Updater and login if necessary
