Moving Elements - Grid Snapping [Solved]
Is there a way to disable this? So I can freely move an element around? The grid snapping is making it impossible to position it where I want and guessing what the coords I need it to have are is tedious
- HappyGrenades
- Likes: 2 x | 1 x
Re: Moving Elements - Grid Snapping
If you mean making the element free to rotate in whatever direction then just click EDIT, go to Model Properties, and uncheck Restrict Rotations.
- Mambanator
Re: Moving Elements - Grid Snapping [Solved]
Go in Views > Grid Settings or type Shift+G to edit grid settings and make it smaller
