painting trouble
painting trouble
Post by weshuiz13 » 21 Jan 2017, 14:53
i think i have found a bug with paintingtools i placed a few elements rotated a few and when trying to paint it with the pen it will paint but it will paint a other location on my model aswell is this a bug if no can you disable it
a life Without cubik is no Life
weshuiz13
Re: painting trouble
Post by CaptainGalax » 21 Jan 2017, 15:11
weshuiz13 wrote: 21 Jan 2017, 14:53 i think i have found a bug with paintingtools i placed a few elements rotated a few and when trying to paint it with the pen it will paint but it will paint a other location on my model aswell is this a bug if no can you disable it
Paint first before you Rotate, this isn´t a bug, and you can´t disable it.
CaptainGalax
Post by weshuiz13 » 21 Jan 2017, 19:07
cubik studio uses a T as a indicator no texture is apply'd when painting a element the back color will chance however the T will remain has has to be painted on its own to get rid of im not sure if this is a bug put using the fill bucked should fill the enire elemt with that color and not the backcolor of the element
weshuiz13
Post by Sphax » 22 Jan 2017, 18:39
The "T" texture is the default texture of Cubik (and "P" for particle texture)
It's a texture and behaves like that. So if you use any paint tool on it, it will behave as any other texture.
Also if you want to paint a face without modifying other faces, be sure to make that face use a unique texture or a unique part of a texture. Cubik can do that automatically for you by going in the Elements Material > ... > Create automatic atlas (keep textures) or (blank)
Post by weshuiz13 » 24 Jan 2017, 18:47
my problem lays in the way cubik uses the pen tool when i paint element1 his front texture red for example cubik paints element3 his front texture aswell :o
so a unque texture will not help much
take a look at 2 screenshots 1 is before the painting is applyd the second is after the paint is applyd
only 1 side of 1 element is painted purple why is the second element pinated purple as well?
this is the point tat keeps bugging me
aswell as the T when i want to paint the full side of the element it will go around texture color difrences for example a gray T and a white background
weshuiz13
Post by Sphax » 25 Jan 2017, 09:31
As I said, if you use the Elements Material feature to create an Atlas (keep textures), you'll get a unique texture for each face of each element, allowing you then to paint easily without the duplicating effect.
