Greetings,
This might probably be a small issue I'm over looking but whenever I export my model as a .json file is seems to render as my texture.png file!
Although in Cubik itself it seems to render properly. Anything I'm doing wrong or simply just forgetting to do?
http://i.imgur.com/jzod5Gt.png
http://imgur.com/a6HwfS7
Thanks!
-Glitch
Model isn't rendering the same ingame! [Solved]
- Attachments
stone_pickaxe.json
- (87.33 KiB) Downloaded 312 times
- GlitcherDOTbe
Re: Model isn't rendering the same ingame!
Works fine for me (besides the fact I don't have the correct texture).
Are you sure you're definitely placing it in /assets/minecraft/models/item ?
100% sure, I'm working of an already working pack of mine I made with Cubik Pro! Could it be something about Minecraft 1.11.2 perhaps?
Now that you say it, I did have this happen to me another time where other would see my bow model animated but I didn't. Wonder why that is
- GlitcherDOTbe
Re: Model isn't rendering the same ingame! [Solved]
Hmnnn after some messing around and making it from complete scratch it seems to work.. No clue what fixed it.. Thanks for the help tho!
- GlitcherDOTbe
